slave cable plug Q
TOM R
slave cable plug Q
Post by TOM R »
anyone know how to remove the slave cable plug from its metal housing ?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
Franz©
Post by Franz© »
It doesn't come out in any salvagable condition.
The rubber surrounding the contacts was vulcanized in place.
TOM R
Post by TOM R »
if i cut the broken case off could i slide it into the new case?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
There not that expensive. Why not just save the headache and get a new one?
Agreed-you can score one for $25 on E-Bay regularly....
TOM R
Post by TOM R »
well dad and i got alot of project vehicles near completeion so a few $ makes a big difference at this point, I bought a used mount woth cover from a guy and it has no guts so we figured it comes apart somehow :wink: thanks for the info :D
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
TOM R
Post by TOM R »
well cut off the housing , sprayed on some lube and used the shop press with wood blocks to press it in worked fine, after disasembly it looks like you could set it in the press and press it out from the front, my only question now is the 2 pins supposed to be on the same side as the key notch for the slave plug or 180* away?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
AmarilloCorey
Post by AmarilloCorey »
TOM R wrote:well cut off the housing , sprayed on some lube and used the shop press with wood blocks to press it in worked fine, after disasembly it looks like you could set it in the press and press it out from the front, my only question now is the 2 pins supposed to be on the same side as the key notch for the slave plug or 180* away?
The 2 pins are on the opposite side of the key notch.
[img][img]http://i36.tinypic.com/o8utn5.jpg[/img][/img]
TOM R
Post by TOM R »
thats what we figured thanks for the help :D
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
