Rear Prop Shaft (Shaft)
Thanks again for the advice on getting the rear drive shaft checked out. The long tube had a bend in it from hitting a rock or from a fork truck lift which caused it to wobble. We had the local machine shop cut the tube out, weld and balance a new tube. $285 later.... yikes. We decided to pull the front one off to see if we could clean the spline to slip again (currently does not slip).
