Left front fender XM708
JimC
Post by JimC »
here are 5 flush rivets in the top of the fender. Four in a rectangle and one centered in front.
They don't attach anything, and I suspect they are just cosmetic hole fillers. My question is, what originally mounted there?
Rdinatal
Re: Left front fender XM708
Post by Rdinatal »
Looks like there was a heater installed at one time. If you look at the engine side cowling(?) you can see plugs for two water hoses.
UZIS9MM
Post by UZIS9MM »
Those are for the optional fender mounted cab heater. My M37 has one but it doesn't get used as the truck is stored during the cold months.
1954 M37.JPG (194.4 KiB) Viewed 43984 times
JimC
Post by JimC »
Thanks.
Nice rig!
JimC
Post by JimC »
It sure is.
