Battery Hold Downs
Battery Hold Downs
We ended up using a set of battery trays and hold downs from the marine store. They are a full plastic tray with stainless steel long bolts and plastic top frames. They fit the full range of batteries. The only mod required is that they are 1/4" each too wide. A simple sabre saw job to cut off 1/8" of each side and right in they went.
