I see OD footman loops available on ebay for $14 plus shipping for a pack of them. I only need TWO. If you have a couple laying around, I will buy them from you for $5
I'm getting closer on having my First Aid Kit installed but now I need a couple footman loops to hold the strap that holds the kit. My 1963 M37B1 does not have the slots in the metal on the side of the seat so these are needed to hold the strap. Unless someone has a better idea that does not require screwing into the metal.
Greg
OD Footman Loop for First Aid Kit
Greg - you are on the right track. I bought a 3 pack of little footman loops and painted them up to match. We drilled and bolted them to the seat side. We had trouble finding the push in rubber bumpers so we bought 3 rubber bumper that used screws from ACE Hardware. I couldn't find the push in ones at NAPA as some guys suggested. Keith
- uglyranger
- PFC
Picked up a well used First Aid Box with dents and rust. I sand blasted, primed and painted it using a rattle can Krylon "Olive" from Wal-Mart. Had a picture of the decal, put it into "Word", resized it to fit the box and printed it onto a "glossy" peal-and-stick 8 x 11 sheet of paper, cut it out and stuck it on the box. Here is the before and after:
