farm truck rustoration
52PLOWERWAGON
Re: its rebuild time
Post by 52PLOWERWAGON »
mounted lights
gamma goat front directionals
infrareds behind grille
I want to remove the screen on my cowl vent and mount a 12 in led light bar under it that flips up when open the cowl vent
what are yous guyses thoughts on this
I also
mounted a 155 tube on the back of the hardtop above the rear window
mounted bolt cutters in cab
mounted an 81 tube on drivers front fender
bolted a 50 cal can to gas can mount on fender
and wired a horse shoe to the grille
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
sturmtyger380
Post by sturmtyger380 »
Interesting idea. How will you get it to shine down on the road since it is so close to that long flat hood?
I would agree that it would be too close to the hood and not illuminate the road very well.
52PLOWERWAGON
worked on wiring all week , well until Thursday....
when the truck tried to blind me when I stripped the end of one of its wires by slamming the wire strippers into my face
my eye hurt for 3 days and was very blood shot
it is perfectly fine now it looks like nothing ever happened to it
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
Post by isaac_alaska »
Note to self: strippers jammed into face can cause bloodshot eyes. :mrgreen:
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Note to self. Continue to use automatic wire strippers.
52PLOWERWAGON
note to self
next time buy new wiring harness
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
petronix will be here tomorrow
maybe by the end of the weekend it will run again
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
Re: its rebuild time 52 m37 for sale
it runs
and its for sale :(
see my ad in swap meet
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
engine is coming out again putting the stock cam back in it
any one wanna buy a hot cam for a 230 with valve springs and hub
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
What didn't you like about it? (Which cam was it?)
52PLOWERWAGON
loved it but it decreased my mpg plus id like to revert back to stock
I ordered it from vpw it is ground by ISKY RACING CAMS
http://www.g741.org/PHPBB/viewtopic.php?f=3&t=7582
specs are in this link
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
Re: farm truck rustoration
and I'm going 12 volt
engine is disassembled
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
I don't know how I missed most of your build, but I just caught up! Tell me about your Pertronics ignition, will it work with 12 volts?
52PLOWERWAGON
swapping distributors to civilian
any one need a military dist
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
