L head mods keeping the info alive
RMS
Re: L head mods keeping the info alive
Post by RMS »
shadbolt is the local cam shop here in Vancouver. he has a small selection of different cams for the long block but im not sure whats the best profile for how i use my truck. i will pick the brains of the guys at delta camsahfts
thanks for the lead
cheers
Kaegi
Post by Kaegi »
there is alot to know about cam profiles and I have never taken the time to study them in depth. That is why I call the guys that know the math behind it.
RMS
Post by RMS »
found a great site with some very cool looking manifolds. http://www.manifoldsbymoose.com/home/plymouth-dodgeImage Image Image
rixm37
Post by rixm37 »
That is a cool page ! I have my original 230 and want to rebuild it with some better performance Moose has some great stuff !
jimmy_stikx
Post by jimmy_stikx »
Has anyone thought to reverse the flow on these? Use the exhaust as the intake and vice versa?
RMS
Post by RMS »
RMS wrote: Image
can anyone provide graphs for 251/265 with dual carb/intake or with a four blade fan. any graphs on the 230
still like to compare these charts to a 230 if anyone has them
M37N55
Post by M37N55 »
Awesome info guys... I had my Can. 251 bored over 40 but the engine was bored over 40 before I got to it. My engine builder bumped the comp to about 7.5-1. He threw in a crank from a semi engine with different rods and pistons... my own estimate is about 277 cu in. So in the beginning I asked him how I could get more power out of this engine and after it was rebuilt his suggestion was to put a small turbo on it... but first I need to find a carb to go with this idea. He told me about a Holley that would be perfect... but I'm not doing that until I find a 24v dis, wires and waterproof set up. I'm going to run the engine stock for awhile first, then we'll see about a turbo idea. My engine builder told me that all of this engines torque is available around 1400 to 1600 rpm... we'll see. I'm going to look for my spec card to make sure I got all this info right.
Love the info... keep it coming
Shane
1951 M37 Canadian
2014 Ram 2500 6.4 Hemi
RMS
Post by RMS »
hi Shane
welcome to the board and lets see some pics! :mrgreen:
.080 over 265 sounds like fun! did your builder use Pontiac pistons? i would toss the crater and get a webber (or two) on before water proof wires. lots of jetting options for the webber and they get blown through all the time 8)
M37N55
Post by M37N55 »
RMS wrote:hi Shane
Hi RMS
So ... you said.... or two ... can you get dual set up for 251 block, because all I've seen is one for the 230. I know there is custom made route.. but I like the idea of the stock look. Thanks for the Weber carb idea, they look more period correct... I will post pictures... but it's very winter here and my shop is a wood shop right now.. making furniture etc.
Shane
1951 M37 Canadian
RMS
Post by RMS »
yes there is a stock dual in/out for the 251/265 but it is very rare. it was only used on 2ton and bigger trucks. they go for $800 - $1500+ :shock:
here is a pic of mine: Image
M37N55
Post by M37N55 »
1951 M37 Winnipeg Canadian Military
20150109_120035_resized (361x640).jpg (162.02 KiB) Viewed 3611 times
Here the project sits and waits for the axles, you can see the transfer case in background with the tranny on the right. the springs are redone +2". The frame sandblasted and Ind. primer at a Mining Equipment rebuild shop. And I have two more pics I just downed off my phone... too cool.
1951 M37 Canadian
M37N55
Post by M37N55 »
20150109_120200_resized (361x640).jpg (175.24 KiB) Viewed 3610 times
The 251+ is stored backwards in the frame, The rest of the truck is out the barn doors under a buried lean-too :lol:
1951 M37 Canadian
M37N55
Post by M37N55 »
20150109_120234_resized (361x640).jpg (198.94 KiB) Viewed 3608 times
WHEN I find the spec card for the this engine ... I will share the details.. I know one thing this 251 felt at home in this engine shop opened in 1954... and he had parts on the self. He sourced out pistons due to milling etc.. so maybe our right RMS.
1951 M37 Canadian
M37N55
Post by M37N55 »
[quote="RMS"]yes there is a stock dual in/out for the 251/265 but it is very rare. it was only used on 2ton and bigger trucks. they go for $800 - $1500+ :shock:
I guess we'll be sticking with single :cry:
1951 M37 Canadian
RMS
Post by RMS »
M37N55 wrote:I guess we'll be sticking with single :cry:
ya I was quite shocked to see how much all the "speed" parts go for.
I look forward to seeing the build card and your truck together
cheers
Robyn
