FRUSTRATED
I'm glad you solved your problem! :D
Today, in between splitting firewood, I started her up several times to hear her purr just because. :D
I can understand that! :D
Congratulations David! Obviously, knowing the reputation of the rebuilder will go a long way in our level of trust when it comes to rebuilt components! Glad you're up and running again!
Thanks everbody for the help and support :D
Distributors seem to be one of the worst components in which to find this type of issues. We've had all sorts of things to come up resulting from bad or misassembled units. Bought 6 new ones a couple of years ago only to find the shaft bushings had been reamed too large. Had to tear every one down to install & ream to size new bushings. Had some with a run of bad coils also, they would last only a few hours until the coil case would split from top to bottom, looked as if they had water in them, had frozen & cracked open.
uglyranger
Post by uglyranger »
Congratulations, and thanks for posting the final "fix".
vtdeucedriver
Post by vtdeucedriver »
Ugly, does that sound like on the G838 site?????? Aparently there are a lot of govt ovhd destributors for the M151 where the shaft is 180 deg out.
Coulda Been Worse
25 hours ani't too bad considering............
Congrats, 8)
