I am going out to hook up my sparkplug wires
bubba_got_you
- SGT
I am going out to hook up my sparkplug wires and need to know what cylinder fires first? And maybe just how to do this in general. (I am used to there being #’s on the regulator)
May God grant me with the serenity to accept the things I cannot shoot, The ability to shoot the things I can and a place to hide the bodies
Re: I am going out to hook up my sparkplug wires
I suspect you mean #'s on the distributor, anyway the firing order is 1-5-3-6-2-4. The #1 terminal on the distributor cover will be the one that is in the approximate 7 o/clock position. Proceed from there in a clockwise direction in accordance with firing order.bubba_got_you wrote:I am going out to hook up my sparkplug wires and need to know what cylinder fires first? And maybe just how to do this in general. (I am used to there being #’s on the regulator)
bubba_got_you
- SGT
yes I don’t know why I said regulator.MSeriesRebuild wrote:I suspect you mean #'s on the distributor, anyway the firing order is 1-5-3-6-2-4. The #1 terminal on the distributor cover will be the one that is in the approximate 7 o/clock position. Proceed from there in a clockwise direction in accordance with firing order.bubba_got_you wrote:I am going out to hook up my sparkplug wires and need to know what cylinder fires first? And maybe just how to do this in general. (I am used to there being #’s on the regulator)
thanks for the help
peter e mark
- SSGT
This is correct.peter e mark wrote:Hello Charles and all, and I notice your reference to the #1 wire position of the distributor as being at 7 o:clock. But is this with me standing on the side of the engine where the distributor is between me and the engine block...?
peter e mark
- SSGT
bubba_got_you
- SGT
Ok she isn’t starting so I am thinking my wires may be off on it is my timing. Witch one is 7 o’clock on the distributor? And how do I make my timing close enough to start?MSeriesRebuild wrote:I suspect you mean #'s on the distributor, anyway the firing order is 1-5-3-6-2-4. The #1 terminal on the distributor cover will be the one that is in the approximate 7 o/clock position. Proceed from there in a clockwise direction in accordance with firing order.bubba_got_you wrote:I am going out to hook up my sparkplug wires and need to know what cylinder fires first? And maybe just how to do this in general. (I am used to there being #’s on the regulator)
#1 is at the position of the 7 on a clock face when looking straight at the distributor. Align the DC mark on the crank pulley with the pointer, remove the distributor cover, the rotor will either be pointing at #1 or #6 terminal on the cap. Makes no difference which one it's pointing at, loosen the 1/4" bolt that holds the distributor in the block, turn the distributor housing so that the cam is just beginning to open the points, retighten the bolt, this is plenty close to start if no other problems exist. Once you get it running, set the timing to 4* before TDC using a timing light.bubba_got_you wrote:Ok she isn’t starting so I am thinking my wires may be off on it is my timing. Witch one is 7 o’clock on the distributor? And how do I make my timing close enough to start?MSeriesRebuild wrote:I suspect you mean #'s on the distributor, anyway the firing order is 1-5-3-6-2-4. The #1 terminal on the distributor cover will be the one that is in the approximate 7 o/clock position. Proceed from there in a clockwise direction in accordance with firing order.bubba_got_you wrote:I am going out to hook up my sparkplug wires and need to know what cylinder fires first? And maybe just how to do this in general. (I am used to there being #’s on the regulator)
Spark Plug Wires
Bubba,
Are these the military thread on wires? If they are not, are you using a regular universal wire kit. If you are, the plug wire ends that go in to the cap have to have a pin on the end of the wire. Look in to the cap from the top the conductor plate is on the bottom of each wire hole.
Rich Szklany
Rich Szklany
