Master cylinder recommendations
Hal O'Peridol
Post by Hal O'Peridol »
After many yars of waiting, I am finally going to start on the M37.
I will be having the brakes ungraded to a dual cylinder setup, what have yall found to be a reliable set up that does not make much cutting into the basics of the body/frame. Thank you.
USAR 1980-1983
1984 M1009 CUCV
1944 GPW 1/4 T
1953 M37 3/4 T
M100 1/4T trailer
1 M416 1/4T trailer
Re: Master cylinder recommendations
Sorry can't help-I run the stock MC.
j mccormick
Post by j mccormick »
I changed mine over to a NAPA 39075 which is the same bore,1 1/4", as the original. It was for a 1978-1980 K 20 Chevy pickup. I had to put a couple holes in the frame for the lines to go through but it was an easy replacement. Joe
vargaspj
Post by vargaspj »
Did you have to "bend" the input shaft slightly per the Ugly Truckling instructions?
j mccormick
It's been a long time since I did it but I went and looked at mine and I didn't have to bend the shaft. Joe
Hal O'Peridol
Thank s guys!
USAR 1980-1983
1984 M1009 CUCV
1944 GPW 1/4 T
1953 M37 3/4 T
M100 1/4T trailer
1 M416 1/4T trailer
In over a half-century of driving M37's, I've never had a MC fail, just get a bit mushy.
However, I have had the metal ends of NOS brake hoses blow off for a real pucker-factor experience.
