Howdy friends!!
Just curious if there's any information concerning wire routing and the stuff required to mount a wiring harness?? (clips, hardware, sheet metal screws)
My 1962 M37wow was used by the road commission as a asphalt truck. I'm guessing since they don't work at night, they made a crappy attempt to convert the truck to 12 volts by ripping the wiring harness out and running what looks like trailer wiring for two brake lights!! What a mess.
I have the wiring diagram - which is nice - but there's little left to show where the wires are supposed to go??
Any wisdom would be greatly appreciated!
Thanks again for your help!!!
Wire Routing / Mounting Hardware / Clips / etc. ???
Elvis A Presley
- PVT
1966 Fairlane GTA
1966 M151A1
1962 M37B1 WOW
1966 M151A1
1962 M37B1 WOW
Re: Wire Routing / Mounting Hardware / Clips / etc. ???
Mosey over to Steelsoldiers.com and dig up the free downloads of all the G741 series truck tech manuals.
The 10-, 20-, and 30- series TM's have illustrations of all the areas of the vehicles.
Flog your printer and learn more about your truck.
- sturmtyger380
I was in the same situation. Looking through the manuals you can eventually piece together how the wiring routes and what holds it down or to the frame. The pictures of thinks like the axle chapter shows part of the frame. Other chapters have photos of other things but in the background show the wiring, vent and brake line placement.
Elvis A Presley
- PVT
Sweet!!! Thank you gentlemen!!
I'll go head that way and see what I can dig up!
Have a nice day!
Have a nice day!
1966 Fairlane GTA
1966 M151A1
1962 M37B1 WOW
1966 M151A1
1962 M37B1 WOW
The parts manual (the big one, there are several) shows all the parts and gives dimensions and often, locations.
Between the manuals I have found EVERYTHING I've needed.
Ignore the chapters, closely examine ALL the pictures and illustrations
If you share where you are located, maybe someone nearby will let you take a look at theirs. Manuals and pictures are great, but if you can see one done right in person, that would answer a lot of questions.
You can add your location information to your user profile, and it will show up in the sidebar on every post you make (though that sidebar may be hidden if viewing on a smart phone). Look for your name near the upper right corner. Click on the little triangle near it, and select "User Control Panel". In the page that pops up, click on the "Profile" tab and fill in whatever information you feel like sharing.
