Timing
LmJohnson 13th
Timing
How do I time in oil pump and Distributor
Re: Timing
Hello LM and welcome!
Set #1 cylinder to TDC, ensure your distributor rotor is also set on #1 spark plug, add about 2 degrees BEFORE TDC timing, ensure you have fuel getting to the carb, then give it a try!
Monkeywrench
Re: Timing
Try searching this:
"Can't get timing right, can the oil pump gear be off"
