Help with Component ID
DCook
Post by DCook »
Please reply with the identification of a couple of components in a truck I'm looking at buying ---
-- Engine Block stamping where the T245 should be is -- TI42*90465 -- Is this a civilian engine?
-- It is a winch equip truck but has an -- MU3-10F -- winch instead of a LU-4. Is that an original equipment winch model for our trucks?
I have not been able to bring up forum discussions when searching for the origins of either of these, so thanks for any help you're able to provide!!
DCook
MVPA Member #23780
1951 M37 W/W, & Field Radio
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
Re: Help with Component ID
The engine type is suspect, maybe a depot changeout in later years or by a foreign gov't.
Is the oil filler pipe bolted to the block or pushed in?
All G741 series trucks were equipped with the Braden LU-4. Many MU-series winches were added by civilian or downstream users, but not OEM gear.
DCook
Post by DCook »
Hey Thanks for your great reply! Very helpful. I don't have a good picture to reference that shows the distributor area, which would answer the fill pipe question. I'll keep searching for details ----
MVPA Member #23780
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
Argie1978
Post by Argie1978 »
Are you sure it isn’t a T149? Those are 218ci (civilian, probably from the late 40s).
Sebastian
Sebastian
DCook
Post by DCook »
Sebastian the picture I have is quite clear, and it's a TI as in eye not a one. this font makes it look like a one not a capitol I.
MVPA Member #23780
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
Argie1978
Post by Argie1978 »
Look, I'm just trying to give a hand. I've never seen a TIx serial.
I've just done a 10 seconds search in Google and I got this I'm attaching....
See the serial the poster is declaring? The other forum member indicates probably it's a T-142. And he just informs what I've pointed out previously (just noted I wrote 149 instead of 142).
Anyways, this is just fast check online. Probably the serial TI is legit and there's almost no info about it to be found.
Sebastian
Sebastian
DCook
Post by DCook »
Finally had a chance to post a picture of the engine stamping in this truck. It is the "V41 Up For Grabs", that I was hoping to be all original. Still haven't figured out where this engine came from, but I think it's Civilian
KIMG0021 Resized.JPG (59.4 KiB) Viewed 1601 times
MVPA Member #23780
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
