What is this for?
What is this for?
DSC01664 (Small).JPG (107.64 KiB) Viewed 5164 times
DSC01665 (Small).JPG (105.19 KiB) Viewed 5164 times
I'm digging through stuff that came with my truck, and I came upon two of these. Anyone know what they are for?
Re: What is this for?
Never seen those on any M37s I've viewed close-up....
greeno
Post by greeno »
Having just taken mine down to the frame I do not recognize those.
M37
YEAR: 1954
Looks to be a unit fab special item. Any holes in the bed wood that match up?
Not a clue here either?
greeno
Post by greeno »
Can we make this a running thread? I got a piece that is making me scratch my head:
M37
YEAR: 1954
Can't tell from the photo: is that hollow or solid? It looks like a short length of flared tubing with a flare nut.
A brake line, fuel line?
OK, here are two stout metal parts, came with my M36, have no idea where they go and what they do. Some sort of wiring protection I believe. Any thoughts....
hal
[url=https://postimg.cc/r0x7dtKD][img]h ... .jpg[/img][/url]
greeno
Post by greeno »
I know this one!
They go on the backside of the taillight brackets. Clips hold the Douglas shells.
This is fun!
M37
YEAR: 1954
greeno
Post by greeno »
m-37Bruce wrote:A brake line, fuel line?
It’s flared on one end like a brake line, no flare other end.
M37
YEAR: 1954
ez8
Post by ez8 »
I'm pretty sure this is for the vent line on the fuel tank. This screws into the fuel tank and then a rubber hose runs from the unflared in up to the filler neck.
Sounds right to me, the length of the flared tube was not mentioned.
OK, thanks for the update on what these big steel plates are for. I will look under my truck to see what is protecting my rear tail light's. NV
Another widget like that tubing thing is found on the bottom of the steering box where the horn wire comes out.
