High speed starter for the Dodge 230...
Hi All,
I'd been harassing Charles at M-Series Rebuild LLC for the past year or so regarding this starter. I finally found the cash to get one and am SO glad I did! Brand new in the box, half the size of my old one, but needed characterization with some fresh 24087 paint!
I installed it today. FYI, those two mount nuts are still a pain in the butt, but well worth the time and trouble! Anyway, once installed I offered a moment of silence then hit the key-the 230 fired up in less than a second! Man was I impressed, so much so that I had to key it off and on a half-dozen times just to re-live the moment!
I can't say enough how well it works, has great torque and speed, and highly recommend it! Many thanks to Charles for making them available, in 12 or 24V.
Oh, Bert, pictures? :)
starters new and old.JPG (29.05 KiB) Viewed 2515 times
starter with 24087 applied.JPG (214.8 KiB) Viewed 2515 times
new starter 1.JPG (34 KiB) Viewed 2515 times
Re: High speed starter for the Dodge 230...
And....
Just in time for the marathon of Winter Storm warnings now up for my neck of the woods and headed East! I also got my tire chains installed and did my PMCS today.
Hope all are well, healthy and safe!
new starter now in place.JPG (44.18 KiB) Viewed 2515 times
RCrombie
Post by RCrombie »
That’s a pretty slick setup! Amazing how the gear reduction starters can be so much smaller but also so much more effective than the old direct drive style. I must say though, I would miss the foot starter. That’s one of the bits of “character” on these old trucks.
Good luck with the snow! Having chains makes a huge difference.
Rob
I agree, very slick, personally I would not miss the foot starter. Congratulations CG, KUDOS to Charles at M-Series Rebuild as well.
Are these readily available or only through Charles & M-Series?
Thanks guys, I don't know how "readily available" they are, but my old one required a lot of finesse with the key to get the old starter to engage-a bit un-nerving in a parking lot with a bunch of folks watching....
Now, for snow, the first storm petered out but the next one rolls in overnight, with Winter Storm warnings posted throughout the region. I've got the truck and camera ready for a joy ride if we get a decent amount of snow.
signsup
Post by signsup »
Hmmm... wonder if this would work on my Dodge WC56 command car? It's not a factory class restoration and I'd rather have it start every time than look 100 percent correct. I also have a M37 in the shop for daily driver type restomod and this starter may be an option for that truck.
I'll go check out the site.
RCrombie
Post by RCrombie »
Haha I just took a closer look now and clued in that your old starter was solenoid operated as well. Was that a modification?
I'm a big fan of the foot starter- it's part of the character of the truck. I suppose if you put in a solenoid operated starter, you could always rig up a switch to the foot starter pedal to still operate it off that.
That starter was in the truck when I bought it. VPW rebuilt it for me several years ago but it's just too worn out to continue grinding with it.
Readily available from Summit and others. Not expensive.
just me wrote:Readily available from Summit and others. Not expensive.
That's really good to know!
BTW, does it have a part # or any specs?
ferroequinologist
Post by ferroequinologist »
Cal_Gary wrote:That starter was in the truck when I bought it. VPW rebuilt it for me several years ago but it's just too worn out to continue grinding with it.
Hey Gary,
Does your old one have any part numbers on it? Think you might sell it? I am building a custom 'what if' MV based on the M37, and want a 'correct' looking starter that isn't foot operated.
Or I could go with the same one you did and just deal with it not being 'period' enough looking.
Glad to hear it worked out well, I might swap one of the new ones in on my 'farm truck' M37. Wife has a hard time reaching the foot starter and she uses it the most.
@ Bruce, I didn't see a part number anywhere on the new one;
@ Ferro, sorry, that old one was hauled off to the dump on Monday. Had I known you'd wanted it you could have had it for the cost of shipping....
Again, sorry,
Thanks Gary, I'm not sure what direction I'm going, but a newer drivetrain might be in my future?
Really Bruce? Why would you do that if your current drivetrain is in good shape? More power maybe?
