Hello. I have several parts left over from my M37 restoration I am working on. All parts are in Carencro, Louisiana and I am interested in trades.
Driver door - bottom rusted but seems repairable.
Passenger door - bottom rusted but repairable.
Trans tunnel - some perforated rust, mainly around the back edge but usable as is if you're not looking for a show piece.
Windshield frame - Flaking paint and typical rust but should be worth using.
Glove box - Surface rust but usable.
Filler Panel above trans tunnel - No significant rust and perfectly usable after cleaning.
Remanufactured floor for driver side under seat - I used CAD software and had this professionally built. Surface rust but in usable condition.
Floor Board Patch Panel - Surface rust but perfectly usable after cleaned. I purchased this from a vendor who sells the panels stamped with the correct diamond pattern but did not use.
Door card (?) - fills the hole in the interior side of either door. Perforated with some amount of rust but usable.
Door latch and window mechanisms - Usable condition. I have a set for both doors.
I can email pics as needed.
I would be interested in trading for
Driver seat in good condition including bucket, rails, and/or springs
Good U-Bolts
New or Reman spring shackle pivot bolts
Glove box door
window crank handles
Other miscellaneous parts.
Doors and Other Parts for Trade
- Passenger Door 1.JPG (27.77 KiB) Viewed 1453 times
- Driver Door 1.JPG (25.88 KiB) Viewed 1453 times
- PVT
Re: Doors and Other Parts for Trade
Hi M,
I have good U bolts from the front, I just need to dig them out. Would you trade me the passenger diamond plate for them? Thanks!
I still have the panels but already bought u-bolts. Let me know if you have other parts you'd be willing to trade.
- PVT
I am in Plaquemine, LA. I don't have any of the parts you are looking for but how much are you asking for the Glove Box?
1954 M37 w/w
