265 cdn m37
Re: 265 cdn m37
Anything you put UNDER the truck that isn't the stock unit runs the risk of getting water in the brake system. The stock unit is sealed and vented at the carb. Anything new will be vented at the cap and that will be in the splash from the wheel. The option is to remote the reservoirs to the firewall if you change setups.
RMS
Re: 265 cdn m37
Post by RMS »
just me wrote: The option is to remote the reservoirs to the firewall if you change setups.
thats the plan
Kaegi
Re: 265 cdn m37
Post by Kaegi »
truck looks great! nice work on the steering. if I read the post on MC correct the 2, 7/8" will perform like a 7/8" single. stock is 1.25". smaller gives more power but requires more pedal travel. with 7/8" MCs it wont have pedal till its near the floor. there are 1.25" dual circuit MCs availalbe in dodge, gm and ford. if you look through post 66 trucks on rockauto you will find them.
RMS
Re: 265 cdn m37
Post by RMS »
Kaegi wrote: if I read the post on MC correct the 2, 7/8" will perform like a 7/8" single.
RMS wrote:my math shows that using two 7/8th masters will get me closer to the stock master.
I thumbed through a stack of raybestos books but couldn't find a dual line mc's with a 1 1/4 bore.....if you have a link please share.
Kaegi
Re: 265 cdn m37
Post by Kaegi »
here is a cast iron one. if you want a later aluminum one look at 1 ton ford vans from the 80s and 90s. those require a remote mounted reservoir which I have fittings and kits for.
https://www.jegs.com/i/RPC/707/R3521/10002/-1
here is another cast iron one that is the corvette style many people use. was used ont trucks as well
https://www.partsgeek.com/gbproducts/MC ... 7433966132
RMS
Re: 265 cdn m37
Post by RMS »
im so confused :?
if this is available why is it never mentioned ? from the big electric days, heli tool, ugly truckling to garbi all reference the 1-5/16.
Kaegi
Re: 265 cdn m37
Post by Kaegi »
maybe they recommend the 1 5/16 for power boosted systems? sometimes upping bore size when switching to power might give better balance and pedal feel.
Kaegi
Re: 265 cdn m37
Post by Kaegi »
here is a Dodge one. we dont need chevy parts on our trucks anyway. ;/)
https://www.rockauto.com/en/moreinfo.ph ... 87&jsn=521
RMS
Re: 265 cdn m37
Post by RMS »
looks to have a smaller reservoir making it easier to get the lid off. and the whay the ports look leads me to believe it could have built in residual pressure vales ?
Kaegi
Re: 265 cdn m37
Post by Kaegi »
that MC is for 67 dodge W300 so definitely would have check valves in it for 4 wheel drum brakes.
