ethenol gas 15%
- SGT
ethenol gas 15%
Hi Guys, Has anyone wondered what is being said about the new 15% ethenol gas that will be coming down the pipe? Should I be using any additives or something else for my truck(M37)??? also still need exhaust manifold...
vinnytruck
Re: ethenol gas 15%
Be sure you are using an upgraded fuel pump with newer ethanol rated rubber parts, same with all of the rubber fuel lines and carb parts. Also put a filter in the fuel line before the fuel pump since ethanol is the best solvent there is so any crap in the tank will be cleaned out by that and will move forward. Do NOT use any kind of gas line antifreeze since they are actually alcohol themselves so you would be adding more alcohol to the mix. And I am sure you have already heard all there is to hear about phase separation and letting gas sit in the tank. The alcohol WILL separate out from the gas once it absorbs moisture from the air. Alcohol is very hygroscopic and readily absorbs moisture from the air. This is not so much of a big deal on modern cars with closed fuel systems. With older cars there are vents open to the atmosphere and moisture moves in and out as temperature changes.
- SGT
Re: ethenol gas 15%
Apparently you can make your own ethanol free gas by taking ethanol gasoline and adding water. Give it a good shake so the water binds with the ethanol and the water, being heavier than gasoline, will sink to the bottom. You then drain off the water and are left with pure gasoline.
Has anyone tried this? I was thinking of doing it for my mule since the gas tank is small enough I could probably get away with doing 5ga at a time.
- milstencil
- CPL
Re: ethenol gas 15%
Find ethanol free gas here: https://www.pure-gas.org/
Rick
Rick
Re: ethenol gas 15%
Also check around your town for yellow handled ethenol free gass pumps. In my small town of Durango Co. we have 4 stations offering entenol free gas. It is as expensive as premium gas, but most of ours is a high octane premium grade ethenol free fuel, around 90 octane. Check though, because we also have 86 octane ethenol free for the same price.
MVPA Member #23780
1951 M37 W/W, & Field Radio
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
Re: ethenol gas 15%
Not in the communist state of NJ, The gasoline laws are just like the gun laws here! You WILL use ethanol gas and you WILL NOT be allowed to have guns!
- milstencil
- CPL
Re: ethenol gas 15%
Become a smuggler Everything is illegal in MA
I bring it in from VT
Rick
Rick
Re: ethenol gas 15%
On the old flat head motors do you still need to put harden valve seats in to protect the valves from getting messed up from the low octane ethanol gas?
Re: ethenol gas 15%
M37s came with hardened valve seats. They were designed to run on fuel way worse than E85...
Re: ethenol gas 15%
my understanding, having recently had new intake seats installed, is that the exhaust are "hardened" but the intakes were not. I had new intake seats installed, and stellite valves put in too. I also think that alcohol gas is in a sense, corrosive, to the innards of the carbs. I run non-ethanol gas in all my "power products" and my truck. It is pretty available here in SC. Some places even have "high-test" gas.
