I just started taking my bed apart for blasting and painting and have a couple of questions regarding the pieces. I have the inner fender well, front panel, the two side panel with inner fender well attached, two bed pieces removed.
1. The bed is in two seperate pieces, should they? I seen others that were welded together
2. The side panel and inner fender well, are they one piece? Mine are attached but I can't tell if its rust or the some of the minor fiberglass work holding it together.
Ed
Bar Harbor Maine
BED REMOVAL
