Transmission Rebuild (early)
Are modern seals available for the front and rear early transmission shafts? If so, where? I'd really rather not use NOS...
Paul Anderson
Re: Transmission Rebuild (early)
There is no seal on the front. The rear seal is National #410308, redi-sleeve is #99212. These are available at most any bearing supply house.powool wrote:Are modern seals available for the front and rear early transmission shafts? If so, where? I'd really rather not use NOS...
