Amazon Prime Photo Sharing Test
Re: Amazon Prime Photo Sharing Test
Oh well that did not work, have to think about this some more.
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Fairbanks, AK
Photo Gallery
What did you do that I failed to do ?
followed the link and opened the photo and then right click and hit "copy image location" and then paste that inside the image tags on here. if you edit or quote my post you should be able to see the text.
i'm not sure why it shows the smaller version of the pic rather than the larger version, and i'm not sure of an easy way to expand it full size, viewed through the site here
Isaac
Fairbanks, AK
Photo Gallery
Fairbanks, AK
Photo Gallery
but it seems to have broken now. i don't know what would have changed, either
Isaac
Fairbanks, AK
Photo Gallery
Fairbanks, AK
Photo Gallery
Isaac
Fairbanks, AK
Photo Gallery
Fairbanks, AK
Photo Gallery
and now it shows the large version, like i thought it would do the first time...
Isaac
Fairbanks, AK
Photo Gallery
Fairbanks, AK
Photo Gallery
I am stumped but I will try later after I finish mowing the back field, thanks Isaac.
then click the "Img" button in here, and it will give you these tags (without the periods)
[img.] put the copied image address here [/img.]
- Capture.PNG (246.93 KiB) Viewed 15088 times
Isaac
Fairbanks, AK
Photo Gallery
Fairbanks, AK
Photo Gallery
I see 1 image in one reply only.
The first link worked for me, Isaac's first image was MIA, when I got to amazon, they asked me to sign in as I am a prime person. Carter, did you do anything else, another thread? Isaac's last tutorial showed up fine?
No Bruce, nothing I have tried has worked. Can not find an image that looks like Isaac's right click post.
I generally lift them from my cpu, or upload them from my fone to Instagram or fb, then place them here sometimes I hit a stumbling block. Does anyone still use the Gallery, and post a link?
