electrical gremlins
electrical gremlins
this is going to be a thread where i ask questions about wiring as i build a complete wiring harness for my m37
ok so ? 1
where do i add a resistor to civi distributer so i don't fry my points
ok so ? 1
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
Re: electrical gremlins
In line with the power to the coil. Depending on how you operate the civy starter, you can easily, can with difficultly or can not wire a bypass of the resistor for starting.
I thought that's where it went
but I couldn't remember what side of the coil
thank you
next question
I am running dual single filament tail lights ,one on each side is going to be reserved for only brake lights
I can easily wire the brake lights
and the other one is going to be a taillight and directional
how do i wire these in to the directionals
thank you
next question
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
job one when making a new harness for your m37 is building a new main light sw pigtail
next rebuild the lights and pick your wire colour
dont forget to leave long tails on all your runs
need to identify what turn signal unit you are running as there are different diagrams for different units. I always run separate wires fore each brake light52PLOWERWAGON wrote:how do i wire these in to the directionals
- CPL
Its easier to use the dual filament bulb for the tail and brake lights and have separate lights for the turn signals. The dual filament is much brighter for the brake light.
Joe
Joe
thy are led so they are plenty bright
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
ok another question
and are the new digital mseries light switches any good ?
I like the modern look
where do you get the parts to rebuild that plugRMS wrote:job one when making a new harness for your m37 is building a new main light sw pigtail![]()
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
- carolinamv
- SSGT
They are good but are static sensitive and will short out VERY easy with no ground or simple shock.
two ways to rebuilt the plug 1 buy new pins local parts store should have some.with boiling water sweat out old, push in new. second roll/strip stock insulation off wire, trim wire for heat shrink style butt connector then crimp.
I will be using the heat shrink connectors I just got a bunch of them to day in the mail
and I got an hour meter ,fuel gauge plus sender and some really cool toggle switches that are shaped like a skull and the eyes glow red when they are on
the hour meter I am installing on the panel that is under the seat facing the drivers door
I think the hour meter is a very practical mod for off road driving
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
how do i wire in a 7 wire directional switch
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
I recently replaced the non-functioning Signal Stat 600, which was wired into the old Army controller box, with the relays and flasher on the firewall, with a 'Stat 900. So I already had a bunch of wires dangling down from behind the dash, when I unscrewed about 8 connections from the passenger, output side of the Army box.
My truck already had turn signals mounted on the front bumpers, and army lights on the rear of the truck. First, I wanted to see the front lights were burned out or not. So, bought 4 6 volt square batteries, the ones with the wire terminals made for dropping into a lantern. Taped them up into a square, then soldered wires from terminal to terminal in series, leaving then one pos lead, and one neg lead wire. Hence, a 24 volt test system. Then, unhooked the wires at the front turn signals, and with the two wires, made sure the bulbs worked, at 24 volts. The front signals have only a pos wire to them, they are grounded thru the fame back to the truck's batteries. I did not test the rear turn signals.
Then removed the 'Stat 600 from the steering wheel, finding some of the wires from that unit were frayed, and likely shorted. Sanded the paint off the steering shaft where the new 900 was going to be clamped, as it is grounded via the metal strap clamp around the steering shaft. Put the 900 on my workbench, and having dropped by a local NAPA and bought matching color wire spools, used weathertight crimp butt connectors with an short sleeve of shrink tubing around each connection. I think pretty vibration proof. I added about 3 feet or so of each wire to the 900's harness. Then wrapped all of this with polyethylene spiral protection, and routed my new "harness" carefully up under the dash and over to the area near the back of the glovebox.
Then, using the included diagram, used my new 24 volt testing system, one wire to a secure ground, the other I touched in turn each of the wires that went who knows where, and as my wife told me which light was on, marked them blue painter's tape. Then added a 15 amp fuse in a wire off one of the pos truck battery terminals, to power the bulb in the 900. I did have to get a NAPA 24 volt bulb to replace the 12V one that comes in the 900. Ordered a 24 volt flasher from Grainger, and after matching and shortening the wires from the 900 to my now marked truck wires, with again waterproof butt connectors, again with a short piece of shrink tubing over each, and crimped female spade connectors on the three wires to the flasher, and when I turned on my battery disconnect, the flasher worked great on all four corners.
I did not use the gray wire to the brake switch, and while the instructions show a wire not only to each corner, but also a wire connecting the two tail turn signals, I did not do that. My truck may already have that, I don't know. I did have to refer several times to the internet to determine which of the three wires went to which spade on the flasher.
Auto wiring is bewildering to me, but by keeping the wire colors the same, it all worked out ok.
As usual, here is a picture. I was at Ft. Riley for about a month before I deployed as part of our 15 man advance party to Saudi Arabia, and snuck over to the rail head where the division was loading up their M1 Abrahm's for shipment to the port, and then on to SA for the upcoming Desert Storm War. The post MP's were patrolling to keep anyone from taking pictures, (why, and who cared?), so I first did a little reconn to find a good place to shot with my trusty Pentax, the same one I had in Vietnam two decades previously. I think this one just gives a hint of the mobility and firepower of an armored division.
all depends on the sw. some options:
900
900
if those dont look right google signal stat diagram and model #
900
900
I used the top diagram to wire in my 900.
thank you this will help a lot
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
