Aftermarket seats
shadow 9er
Aftermarket seats
Post by shadow 9er »
Howdy,
As I'm in the planning stage of my M37 project, I was wondering...
What aftermarket seats or seats originally from a different vehicle have people used in their Resto-mod M37?
How did you mount those seats? Did you bolt them to the existing seat box/ sheet metal in the cab, or did you relocate the battery and remove that sheetmetal, then make new seat mounts?
I've found some aftermarket bucket seats I'd kinda like to use, and I'm looking for ideas.
I kinda like the idea of retaining at least the passenger seat box for storage, etc... but if I ever get around to building my extensive roll-cage, I'll need to go a different route.
Declan
Re: Aftermarket seats
You can make your own springs and seat pans. Model A Tudor rear can work for passenger with mods and the front driver can be modded for the driver side. Not an inexpensive option, however.
52PLOWERWAGON
Post by 52PLOWERWAGON »
my first one had a bench from a ford
and my second one I ditched the ply wood and bolted a seat from an m35a3 to the stock rails
it is very comfortable and the install was simple
Humvee seats are cheap and plentiful
otherwise I read mrap seats would work
look up fred Williams' m37 the dumpster on the fourwheeler net work I think that had aftermarket seats
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
