Ins & Outs of Transfer Case Rebuilds
Re: Ins & Outs of Transfer Case Rebuilds
Thanks to everyone for their for their help! I spend some time today doing my "homework" today so things go smoothly with the students tomorrow.
I'm thinking I can make a spacer for setting the idler bearing preload outside the case by measuring the thickness of the case and duplicating it with short spacer. I'll try and find a piece of hex stock and then I can put a wrench on it to torque the assembly.
As far as an arbor, it looks like I just need to be a few thousandths under the diameter of the idler shaft and a bit shorter than the idler gear so I can remove it from the case with the arbor holding the inner bits.
Curious to see what we find this week. It looks like the case has a date code from '54 and the truck's a '51, so it's been replaced somewhere along the way.
Sure would be nice if someone (hint-hint) would take a LOT of pics of the process of rebuilding one of these! I have to replace my shift rods (rust) and figure I'll find other bad stuff. I want to install an oil cooler (external, pump driven), has anyone done this?
I'll try and take some photos, of course I guess they won't be of much use if we screw things up
Ran the T-case through the jet wash today, I love that thing! Clean in 15 minutes. So far it looks like there was a bit of shifting going on between the mounts and the case, which I understand is typical. One bolt on each side was a bit loose and I hope that was the "clunk" I've been chasing. Fortunately the holes in the brackets were not all wallowed out. Once the box was clean I spent some time turning flanges and shifting levers. My concern at the moment is the backlash in the "input" shaft, it has the most play by far and I'm very curious to see what we find tomorrow. It does not have the play of a dog ring gearbox, but it's close...
I just finished rebuilding an NP200 for my truck. If you need photos, I took some during the process. Just let me know if you need anything specific, and I'll check my image file.06boblee wrote:Sure would be nice if someone (hint-hint) would take a LOT of pics of the process of rebuilding one of these! I have to replace my shift rods (rust) and figure I'll find other bad stuff. I want to install an oil cooler (external, pump driven), has anyone done this?
Charles at M Series Rebuild has done the external oil pump and cooler on the NP200 transfer case. He's posted here about it in the past, or you could call him.
He also has stainless shift rods for the NP200. Well worth the expense to prevent future leaks.
Which manual shows the disassembly and repair of the transfer case?
TM 9-8031-2 Power Train, Body and Frame for 3/4-Ton 4x4 Cargo Truck M3706boblee wrote:Which manual shows the disassembly and repair of the transfer case?
Well, I'm ready to get into it. The tag on the bottom says it was rebuilt in '75. Almost no play at any of the yokes- all turns smoothly, so I hope to get it done with new seals and shift rods. Got my fingers crossed!
- DSC00692 (Small).JPG (134.37 KiB) Viewed 2609 times
SUBSCRIBED!
I'm getting ready to do mine too. Please post pics of your progress. I'm waiting on parts before I pull mine.
Clark
Clark
Andy, I'd guess that there's a small piece of shim unaccounted for, and it went through those gears, breaking out a chunk of that one tooth?
One of the NP420 transmissions that I disassembled had the same failures of the shims, and the PTO was missing an entire tooth on one of the gears. The broken tooth and the remains of the shims were in the bottom of the case. Oddly enough, until I tore it apart, there was no indication of anything wrong internally, other than the usual sloppy shifting.
Light reading:
https://www.scribd.com/doc/87972233/Gea ... s-SEBF8193
Thought some of you may appreciate this.
Good stuff. Thanks for posting that link.ashyers wrote:Light reading:
I have some random NOS gears in my pile from buying grab bags from ABLinn. Shoot me some good pics and some dimensions of that gear and I'll see if I have a match.
