R2 crash truck
Tuko
Re: R2 crash truck
Post by Tuko »
Looks like they mixed up the flanges
51 Dodge M37 W/W 4BT/NV4500
My G741 Registry Entry
isaac_alaska
Re: R2 crash truck
Post by isaac_alaska »
Looks correct to me u less its a centered rear axle... But my experience is very limited and I can't remember for sure lol
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Re: R2 crash truck
Front drive shaft has Bow Tie shaped flanges on both ends.
The transmission to transfer case shaft has Square flanges on both ends.
The rear drive shaft has CV joint flanges on both ends.
What have they proposed to correct this for you?
tomor13
Re: R2 crash truck
Post by tomor13 »
The unit is in and their a 5 hour drive away. In contact with them now. They did take the shocks back. Research lead to m-37 shocks do not fit an R2. Much larger. This truck is giving me fits. Now the disk brake conversion from helitool doesn't fit the front. Contacted them as well. Hope to have answers this week. Reply is slow my computer died. Needed a new one. Need to vent this project is frustrating the :?: out of me.
tomor13
Re: R2 crash truck
Post by tomor13 »
Got the brakes worked out. I'm a bone head. Shocks installed. Prepping new fuel tank. 35 gallon one. Vintage contacted me back. Left with questions on that. Looking for Ford Zf 5 speed. Like finding the city of Atlantis around here.
tomor13
Re: R2 crash truck
Post by tomor13 »
New update pics. Shocks, power steering, brakes, tank install started.
tomor13
Re: R2 crash truck
Post by tomor13 »
More pics...
Re: R2 crash truck
Looks like you are making good progress now. What is the fuel tank from? Will it fit into the original tank area without a bunch of modifications?
tomor13
Re: R2 crash truck
Post by tomor13 »
Tank is from a bronco II. It's close but i will raise the rear floor over it about 3 inches.Outside of the truck is what I'm trying to keep as close to original as possible. This wont affect the way it looks. Just allow a 600+ range when driving her.
superbee70
Re: R2 crash truck
Post by superbee70 »
What are you doing for steering? is that the stock column? What are you using for the pitman arm? Have my axle conversion figured out, now trying to decide which way to go for steering.
tomor13
Re: R2 crash truck
Post by tomor13 »
Power steering conversion kit from snake river. http://www.snakeriver4x4.com/ . Reuse original pitman arm. You can go with a replacement steering column they sell. But, I kept stock. They will machine one of the uni joints to fit the stock column.
tomor13
Re: R2 crash truck
Post by tomor13 »
Found a zf transmission. Now to get all related parts and get in the truck.
tomor13
Re: R2 crash truck
Post by tomor13 »
Just got new glass.Among other things. Need to replace weatherstripping. Where do I get it? Glass place had no clue. Doors and all. Remember its an R2.
isaac_alaska
Re: R2 crash truck
when i needed weatherstrip i got it from vintage power wagons, and windows i had cut from DOT rated safety glass from cardboard templates. This was on a FFPW
Isaac
Fairbanks, AK
Photo Gallery
Re: R2 crash truck
John at Mid West Military has all of the rubber you'll need.
www.midwestmilitary.com
