'51 M37 Build
rcamacho
'51 M37 Build
Post by rcamacho »
Starting build thread.
Day 1
'51 M37
rcamacho
Re: '51 M37 Build
Post by rcamacho »
In the garage working on the tear down.
Front sheet metal off
In the garage
In the garage
'51 M37
isaac_alaska
Re: '51 M37 Build
Post by isaac_alaska »
Good start, looks like a fun project!
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Re: '51 M37 Build
The truck looks to be fairly complete.
52PLOWERWAGON
Re: '51 M37 Build
Post by 52PLOWERWAGON »
wow I love the first pic id like to see more like that 8)
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Re: '51 M37 Build
Looks like your truck was growing!
That first set of photos is pretty wild. I look forward to more, with less lichen and moss of course :).
rcamacho
Re: '51 M37 Build
Post by rcamacho »
Anyone know the clutch linkage disconnects? It's a tad hard for me to see.
'51 M37
Re: '51 M37 Build
You can pull the cotter pins out of the pivot pins and drop that part out rather easily. The part has two "Y" shaped yokes on it.
rcamacho
Re: '51 M37 Build
Post by rcamacho »
With the PTO attachment there is very little access to disconnect the clutch linkage inside the frame rail. I'll likely pull the whole clutch/brake pedal shaft assembly from the outside of the frame rail after disconnecting what I can from the other side.
'51 M37
