Mystery part with no diagram
marc8_2
Post by marc8_2 »
Does anyone know where this cc683057 Stop-manifold exhaust valve goes......... There's no diagram in the book just saying there only needs 1
isaac_alaska
Re: Mystery part with no diagram
Post by isaac_alaska »
Got a picture of it? Sounds like either the fording valve or the heat riser valve to me. Both attach to the manifold, but only the heat riser valve is part of the exhaust. If so it goes between the intake and exhaust manifolds, just below the carburetor
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
w30bob
Post by w30bob »
Hi marc8,
The part you listed isn't used in the T245 engine as best as I can tell. The part number isn't listed in the ORD and the pic I found of that part isn't anything I recognize. The part number you mention is an exhaust manifold heat riser stop, which limited the travel of a circular valve installed at the collector end of an exhaust manifold. It was used in Chrysler V-8 engines except the 426 hemi, but I don't see it mentioned as used in the straight 6 flathead. What "book" are you referring to?
marc8_2
Post by marc8_2 »
It's in t249 book Group 108 page 31 3rd last at the bottom of page
marc8_2
Post by marc8_2 »
This is the only thing I can find
marc8_2 wrote:It's in t249 book Group 108 page 31 3rd last at the bottom of page
Canadian truck with the 251 long block engine?
marc8_2
Post by marc8_2 »
Ya
38-54 Ply Dge Chry Des stop heat riser valve 683057 687691 NOS
I find it as a civilian part.
marc8_2
Post by marc8_2 »
Found it looks like 1/2 my trucks are missing it only the most original truck still has it
marc8_2
Post by marc8_2 »
This that it looks like new
marc8_2
Post by marc8_2 »
It hits the pipe to stop heat valve
isaac_alaska
marc8_2 wrote:Found it looks like 1/2 my trucks are missing it only the most original truck still has it
I think I remember seeing something like this on my WM300 civvy power wagon. Always wondered what a valve was doing in the middle of the exhaust pipe
Isaac
Fairbanks, AK
Photo Gallery
