R2 crash truck
Re: R2 crash truck
Truck is closer to transplant. Only a couple of more things to remove for reconditioning. Then put it all back in.
- 20150531_190211.jpg (135.17 KiB) Viewed 9691 times
Re: R2 crash truck
Looks like this now. Soon... Soon
- 20150703_164424.jpg (70.44 KiB) Viewed 9650 times
- Site Admin
Re: R2 crash truck
This will be Great once done, Thanks for posting your progress
MM
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
Re: R2 crash truck
She's fighting this every step of the way. 4 hours today just to get hubs off front axle
Re: R2 crash truck
Wow! that's brutal!
Please keep us posted!
Re: R2 crash truck
More pics on slow progress.
- 20150913_175129.jpg (45.16 KiB) Viewed 9546 times
- 20150830_190403.jpg (78.19 KiB) Viewed 9546 times
- 20150830_190352.jpg (86.84 KiB) Viewed 9546 times
Re: R2 crash truck
Hey, good work-keep after it!
Re: R2 crash truck
I have enjoyed following your work progress and am curious as to what you are using to coat the front end of the frame?
Re: R2 crash truck
Wire wheeled the loose rust off the used Rustoleum rust converter on it. then semi gloss black. Getting front ready to hang motor. Get paint on it to make stuff later easier to do. Hope to have 3rd members back in axles next weekend as well as redone xfer case. Then back on frame.
Re: R2 crash truck
More updates and a suprise.
- New front hubs.
- 003.jpg (46.71 KiB) Viewed 9392 times
- rebuilt front axle. Rear as well.
- 000000002.jpg (61.02 KiB) Viewed 9392 times
- Back on wheels
- 001.jpg (62.84 KiB) Viewed 9392 times
Re: R2 crash truck
Now for a surprise.
- Can you guess whats wrong. Done by VINTAGE POWERWAGONS
- 20151224_135512.jpg (120.22 KiB) Viewed 9392 times
Re: R2 crash truck
New shocks. Don't fit either front or rear. Fully extended don't reach shock post. Suppose to be replacements.
- Direct replacements my butt.
- 20151224_142409.jpg (41.01 KiB) Viewed 9392 times
Re: R2 crash truck
One more whats wrong. This and diffs were done at vintage power wagons.
- Aaahhhhhrrgggg.
- 20151224_135439.jpg (106.25 KiB) Viewed 9392 times
Re: R2 crash truck
Today was going to put in rebuilt drive shafts. Only got the front one on. And you can see why. Probably the last nice day till spring that I'll get outside to work on her. And it was wasted.
Re: R2 crash truck
Haven't seen enough transfer cases to spot the oops on this one
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Fairbanks, AK
Photo Gallery
