M37 fording kit
Theosaf66
M37 fording kit
Post by Theosaf66 »
Hi I am Theo from Greece and I am new in the forum,
I have a fully restored (soon I will share some photos of mine) M37B1 and I am looking for a fording kit
anyone???
Theo
Theo
M151A2 Ford 1970
M416A1 1967
M37B1 G741 1962
M101A2 1990
Re: M37 fording kit
Welcome to the g741 forum!
PM sent.
carolinamv
Re: M37 fording kit
Post by carolinamv »
Does anyone just sell the intake pipe?
-Jay
MVPA#31295
http://www.mvcconline.org
3/3 CAV HWB
Re: M37 fording kit
carolinamv wrote:Does anyone just sell the intake pipe?
By "intake pipe" do you mean the rigid pipe that bolts to the bracket on the windshield frame, or the flexible hose the connects the rigid pipe to the air cleaner shroud inside the engine compartment?
One of the vendors (Midwest Military?) sells a new equivalent of the flexible hose, cut to length.
The intake pipe should be relatively easy to fabricate; it's basically just a length of straight, thin-wall pipe with a 90deg elbow at the bottom. I can measure the one I have and send you the dimensions if you want. Do you have the mounting bracket for it?
carolinamv
Re: M37 fording kit
My truck came with the mounting bracket installed, but no pipe. I need the flex hose and pipe. The exhaust pipe is mounted horizontal on the pass side bed side in it stored position , not in use.
-Jay
MVPA#31295
3/3 CAV HWB
Theosaf66
Re: M37 fording kit
Post by Theosaf66 »
looking at least for the exhaust to placed horizontal for display, I s any one know someone to making it?
Theo
M151A2 Ford 1970
M416A1 1967
M37B1 G741 1962
M101A2 1990
