NOS and Used m37 parts in VT
Hi all, I am selling a bunch of m37 parts. Some are NOS, some are used. All prices do not include USPS shipping from VT. If you have any questions or want specific pictures of an item let me know. I will be at the COMVEC show this Saturday if you want to save on shipping. I have a ton of other little things I don't have time to list, if you need something I don't list send me a message, I may have it. If you are a Steelsoldiers member you can see pictures here:
http://www.steelsoldiers.com/showthread ... highlight=
I am removing items as they sell, so this list should be up to date.
NOS Rear axle gasket sets: $5 each.
NOS Starter O-Rings: $1 each.
NOS Accelerator Dust Boots: $5 each.
NOS Canadian Shift Boots: $10 each. These fit USA Dodges as well.
NOS Valve Cover Gaskets: $1 each.
NOS Wheel Cylinder Rebuild Kits: $5 each, 4 for $16
NOS Tie Rod Ends: $20 each. I have 6 left hand ones, no rights.
NOS Driveshaft Deflectors: $5 each. These protect the pinion seals from dirt and debris.
NOS Bumper Shackle Pins: $5 each. 1 LEFT.
NOS Throwout Bearing: $20.
NOS Brake shoe clips: $5 for 20
NOS U-joints for the jackshaft: $15 each.
NOS Rubber Tailgate Chain Covers: $8 for a pair.
NOS Lower Steering Box Covers: $5 each.
NOS Thermostats 180 Degrees: $15 each.
NOS Right side hood panels with welting: $25 each.
NOS Rear brake hoses (these also work on the front, but are a couple inches longer): $10 each.
USED Jackshafts: $20 each.
USED Jackshaft Yokes: $8 each.
USED Oil Sender with Douglas Connectors 0-120 PSI: $10 each. 1 LEFT
USED Battery Cable Grommet Retainer with bolts: $5.
USED Set of generator brackets: $15 for the pair.
USED Throttle linkage set up: $25.
USED Master Cylinder Tops with Fill Plugs: $5 each.
USED Oil Filter Canisters: $ 10 each.
USED Right Hand Thread Lug Nuts: $0.50 each. Also fit singled out deuces and five-tons.
USED Driver's side Taillight wiring guards: $5 each
USED Radiator support bracket: $5
NOS Generator End bell: $25 either piece
USED Heater dataplates: $5 for set of 2
Door Spare Tire Carrier Handle NOS $15 USED $10
USED Engine Oil Dipstick Assembly $10
NOS Rear Hub Seals Outer $10 each
NOS Throttle Return Spring Extensions $5 each
NOS Pinion nut: $5
NOS Starter Drives: $4 each.
NOS Water Pump Back Plates $5 each
NOS Left Hand Thread Lug Nuts $3 each
NOS Front Marker Light Lens $20
NEW Cowl Vent Gasket $15 each
NOS Horn Button (green) $25
NOS Glovebox door latch, knob and pin set $18 each
NOS Pinion nut: $5
1952 m37
1956 R2 Crash Truck
1953 m101
1958 xm389
1956 R2 Crash Truck
1953 m101
1958 xm389
Re: NOS and Used m37 parts in VT
Its about time you got this list on here!!!
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
Black Ops,
PM sent.
thanks,
PM sent.
thanks,
PM Sent.
Thanks Jake. I got the parts today. Just what I needed.
Rob
Rob
I added a few more things to the first post, and some more stuff here.
NOS/USED Escutcheons $3 each
NOS Front Hub Bearing Adjusting Nut (Outer) $8 each
NOS Throttle Bell Crank to Carb Rods $8 each
NOS m37b1 Blackout Stoplight mounting kit $10
NOS Hood Mounted Windshield Hold Down $10 each
USED Hood Mounted Windshield Hold Down $5
NOS Temperature Gauge with bracket, connectors have corrosion $15
USED Fuel Gauge with bracket, some scratches $10
USED Cab Weatherstrip retainers $12 for a set of two
USED Windshield Arms $5 each
1952 m37
1956 R2 Crash Truck
1953 m101
1958 xm389
1956 R2 Crash Truck
1953 m101
1958 xm389
USED Master Cylinder access plate with screws $25 Has been sandblasted and had some primer
USED Hood Mounted windshield bumper brackets $10 for a pair (sandblasted) These mount on the hood and hold the rubber piece the windshield rests on when folded down
USED Windshield Pivot Brackets (sandblasted) $20 for the pair These are the brackets that the windshield pivots on and the mirror mounts on
USED Windshield arms $12 for a set of two or $6 each. (sandblasted) 3 left.
NOS Starter Button Rubber Pads $6 each
USED Jump seat mounting brackets $10 for the set of 2
- m37 pto plate.jpg (159.4 KiB) Viewed 3746 times
- m37 sandblasted parts.jpg (132.85 KiB) Viewed 3746 times
1952 m37
1956 R2 Crash Truck
1953 m101
1958 xm389
1956 R2 Crash Truck
1953 m101
1958 xm389
PM sent on the two windshield arms.
52 M-42
52 M-42
I've got some NOS throwout bearings with the carriers for $30 each.
- m37 throwout.jpg (87.8 KiB) Viewed 3799 times
1952 m37
1956 R2 Crash Truck
1953 m101
1958 xm389
1956 R2 Crash Truck
1953 m101
1958 xm389
PM sent.
I have a few NOS fan belts for $10 each.
- m37 belt.jpg (186.31 KiB) Viewed 3688 times
1952 m37
1956 R2 Crash Truck
1953 m101
1958 xm389
1956 R2 Crash Truck
1953 m101
1958 xm389
NOS Door Striker plates - $6 each
Set of 2 NOS brake shoe return springs - SOLD
Speedometer pinion drive - $5 each
Speedometer drive nut - $5 each
1952 m37
1956 R2 Crash Truck
1953 m101
1958 xm389
1956 R2 Crash Truck
1953 m101
1958 xm389
PM sent for updated list.
I also have a 100 amp regulator for for $75. It looks NOS but I'm not 100% sure and I haven't tested it.
- 25 amp generator.jpg (187.44 KiB) Viewed 3374 times
1952 m37
1956 R2 Crash Truck
1953 m101
1958 xm389
1956 R2 Crash Truck
1953 m101
1958 xm389
Another pic of the regulator.
I also have some spark plug wire wrenches for $10 each. There are different brands.
1952 m37
1956 R2 Crash Truck
1953 m101
1958 xm389
1956 R2 Crash Truck
1953 m101
1958 xm389
