NOS turn signal kits. this is the kit added orignally on m-37's (and others)before the transistorized ones came out in the late 60's.
http://cgi.ebay.com/ebaymotors/M-Series ... 0015071924
Turn signal kits
Turn signal kits
68 M-715 MVPA# 2710
What these kits are is trouble with a capital"T". The later solid-state kits are 10,000 times better, longer lasting, & more reliable.
My reason behind my statement is this, it isn't that they aren't ok when working. The issue is these control boxes are sealed, the flasher & other components are in the box. Lots of aggrevation to get into the box to replace components if you can get in it at all & if you knew the price of a flasher for that box, just the cost will break your heart. The solid-state system is much less trouble to install with half or less than half the wiring that is involved with the box type. By all means use what you have until it gives trouble, but if a replacement is needed or one is doing an initial installation of turn signals, using the old style is not a sensible decision. You can pick up a 24 volt flasher at NAPA (263-4) that works with the solid-state system & install it in 5 minutes. Not true with the old system.gwalker wrote:I cant speak for anyone else, but on my 715 (that type were orignal equip on the 715) which I have owned for 13 yrs now, the t/s have never failed, that makes 40 yrs come oct., i cant imagine wanting better service
