Rear Differential / Ring & Pinion Options
dispatcher1011
Post by dispatcher1011 »
Hello all,
I think I may need a ring and pinion for in my 1954 M37.
Where can I find the best deal on a ring & pinion?
Keeping it stock.
Might add spider gears while it is that far apart, too... so any help there too would be great.
Seems that some moisture got in the axle.
I might post up some pics later, too, of it.
Thanks in advance.
Re: Rear Differential / Ring & Pinion Options
Might be easiest to get a used center chunk from someone here on the forum-several guys have parts trucks....
Brigand
Post by Brigand »
dispatcher1011 wrote:Hello all,
Keeping it stock.
Thanks in advance.
What part of the country are you in. I've got a couple spare pumpkins in So Cal.
Brigand aka Bob Thompson
I would never join any club that would have me as a member.
dispatcher1011
Pennsylvania... Shipping might be kinda high?
Brigand
Post by Brigand »
dispatcher1011 wrote:Pennsylvania... Shipping might be kinda high?
True, Shipping would probably make them unatractive. The good news is that the 1 ton PW's from WDX through WM300 use the same diff. You should be able to scout one up close to home.
