high charge rate
lewisgrace
- PVT
high charge rate
the charge rate on my m37 is always in the region of 28 to 30 volts even on tickover, sometimes even entering into the red area. after a trip of over 200 miles going to the War and Peace show, which incidentally was terrific, the charge rate was towards 30 volts . Im assuming I have regulator problems, what do you learned gentlemen think many thanks for your thoughts . Bill U.K.
Re: high charge rate
I wouldn't be overly concerned about 28 volts, remember most 12v systems charge pushing 14v. You can turn the voltage regulator back with a screw driver and a multimeter. Make sure you check the voltage with said multimeter first though to make sure the gauge isn't giving you an inaccurate voltage which is quite possible
