ADD-A-LEAF SPRINGS
ADD-A-LEAF SPRINGS
I am putting a 360 into my M-37. I want to add extra leaves on the front springs for the extra weight. Does anyone know of any bolt on kits out there that will fit the stock front springs?
Re: ADD-A-LEAF SPRINGS
wouldn't the 360 weigh less than the stock flathead ?
The weights I've seen say the 360 is about 200 lbs. more.
- CPL
From my experience with add-a-leafs, I would stay away from them. Their spring rates are usually quite different than the factory spring leaves causing the originals to bend right at the point where the add-a-leaf end.
Paul in Janesville, Wisconsin
1953 m37 parts truck
MVPA and MVPG member
Well, adding a winch would add about 250 to the front, so if you're running a non-winch model, the 360's engine weight would be close to the 230 with winch, so the springs should support it. I know of no kits to add leaves; perhaps you could cannibalize some plates from an extra spring and add them.
I would have to agree with Paul and Gary.
Thanks for the input guys. I already have a winch mounted. I reckon I'll have to find some old springs or some material from a spring shop.
Years ago, (well, decades, actually
) Weyerhaeuser Logging Co. had a standard spring modification they used to do to the surplus M-37's they bought. I believe they added 1 to the front and 3 to the rear spring packs. We would see their trucks occasionally when they would sell them off (being a logging company, the trucks were pretty hammered).
I don't know how this worked out for them, but their trucks were pretty much off road all the time.
I may not even be remembering the number of leaves correctly; it was a long time ago............
52 M-42
52 M-42
I have some extra leafs that you can cut and add. I think I added 3 per front side when I had the Hercules Deisel added. See thread at:
http://www.g741.org/PHPBB/viewtopic.php?f=5&t=4870
1962 M116A1 Generator trailer
1964 M101A1 3/4 ton trailer
