Water pump question?
outsider
Post by outsider »
Did the later model water pumps use a shorter(thinner) spacer on the hub between the pulley and the fan blade? My old style (with the grease cup) water pump took a dump so I ordered a new one. Well got the new water pump and the fan hub isn't as deep on the new style one. So if I use my old fan spacer the fan will only be held by the bolts and won't be seated on the hub center.
Any info or ideas on this?
Steve
DJ
Re: Water pump question?
Post by DJ »
You'll need to have the spacer shortend. I had a machine shop do it. There is a post on here about it.
outsider
Post by outsider »
Thanks, I figured that was the deal, but I was hoping I was wrong. As I want to keep all the original parts in case I want to put it back to original someday. I guess I will have to see if I can make a thinner one so I can save the old one.
Steve
WarrenD
Post by WarrenD »
I'd suggest trying to see if someone has the correct thinner one. Try Bob Stahl in MA, he has loads of take-off parts. Phone only: 508-three-eight-four-76-nine-eight.
DJ
Post by DJ »
Check with John,@ Midwest Military I think he had the original length ones. I found out after I had mine shortened, I think!! CRS comes into play when you get old.
Tim Powell
Post by Tim Powell »
You could also talk to Charles Talbert, M-Series Rebuilders @ (704) 474-4683
http://www.mseriesrebuild.com/
nortonscustoms
Post by nortonscustoms »
Instead of cutting down the old spacer I ended up making a new spacer with a pilot. Wanted to keep the fan in the original spot in relation to the shroud and radiator.
outsider
Post by outsider »
"Instead of cutting down the old spacer I ended up making a new spacer with a pilot. Wanted to keep the fan in the original spot in relation to the shroud and radiator."
Nice work! I like the idea of the pilot.
Steve
Nice job on turning that spacer.
Tim Powell
Well, that is one fine looking machine job on the spacer!!
Sal
Post by Sal »
How far into the shroud should the fan be ?
Sal
:mrgreen:
1954 M37 WO/W
1969 M101A1
Tim Powell
SAL!
I went out and took a few pictures of mine but the page is telling me the board quota has been reached?? I can send you my pictures if you like?? Not sure why I can't post them??
Tim Powell
OK, go to the last page of my photo album on this site!! I have three pictures posted of the fan blade and shroud! Hope this helps?
Sal
Post by Sal »
Mine looks about the same as yours. Thanks Tim
Sal
:mrgreen:
1954 M37 WO/W
1969 M101A1
cuz
Post by cuz »
Here's two of Tim's pics. Tim the board quota references the ability to load a photo straight from your computer to the message board. This is because the photo is then stored by the message board. You can still link any photo loaded on another web site or page by using the function with the photo's url.
