Steering Knuckle Grease
- HingsingM37
I know this was posted on the old forum but I cannot remember how much (tubes?) grease got packed into each of the the steering knuckles? It seems it would be easier to pack the grease in during the axle assembly rather than pump forever with a grease gun through the zerk?
- HingsingM37
I am referring to the front axle steering knuckles which house the universal joints for the front axle shafts. They are called steering knuckles in my manual. I am not familiar with the term "RZappa". I have heard of Frank Zappa
on jeeps we call enm rzappa joints, you take gear oil and bearing grease mix it around 50/50 to the consistsancy of pudding so it is to thick to leak out but thin enough to flow and not stick to the sides inside the joint ball cover thing, I used a thrift store electric hand beater
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
OK...I did some research, and here's what I came up with. There is no such thing as a "rzappa" joint. There is, however, a "Rzeppa" Joint which is also named after its inventor.
The ordinary "garden variety" of U-joints that we're all familiar with in our drive shafts is technically called a Cardan Joint, after the guy who invented it way back when.
The Rzeppa Joint is the CV joint that is commonly used in modern front-wheel-drive cars and minivans. It is also used in lightweight 4-wheel-drive vehicles with independent suspension. They are not necessary for our trucks and old jeeps with essentially straight axles.
Having replaced a number of them for different people, I can assure you that they would not hold up to the rigorous demands placed on them in heavier vehicles with the "wish I were somewhere else" sort of drivers who usually operate them for the armed forces.
Re: Steering Knuckle Grease
Each joint holds approximately 2.6 lbs. of NLGI#2 grease. You could pack some into the joint cavity during the build up however you will never be able to fill it completely that way. The easiest way to do it is to remove the zerk fitting from the top bearing retainer plate, install it in place of the plug on the surface of the axle tube ball. Pump grease directly into the cavity until it comes out the hole in the top retainer plate. It is now full, pumping directly into the cavity is much easier than pumping through the top bearing. Replace the zerk in the top plate & install the plug.HingsingM37 wrote:I know this was posted on the old forum but I cannot remember how much (tubes?) grease got packed into each of the the steering knuckles? It seems it would be easier to pack the grease in during the axle assembly rather than pump forever with a grease gun through the zerk?
- HingsingM37
It seemed like I dug a few pounds out of each side during disassembly. Thanks again Charles. Your help and experience is appreciated as always
Holy cow! Why didn't I think of that? So simple. Good show, Charles.The easiest way to do it is to remove the zerk fitting from the top bearing retainer plate, install it in place of the plug on the surface of the axle tube ball. Pump grease directly into the cavity until it comes out the hole in the top retainer plate.
I must say, though, that when I did my knuckle rebuild I bought a pneumatic grease gun. Four pounds of grease can tucker one out, especially when in the comfortable position of being threaded behind the bumper, and wrapped around the front wheel. That little honey paid for itself during the first lube.
Dave Ostlund
1941 WC9
1952 M37 W/W
1953 M38A1
M116
RTFB
1941 WC9
1952 M37 W/W
1953 M38A1
M116
RTFB
NLGI#2 grease, this is basicly car cv joint grease for front wheel drives right?
after makin up the grease mix for the jeep i spooned it into a spare greasegun with an empty tube in it and pumped it in,cj2a jeep has a large fill hole
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
The NLGI#2 spec is chassis grease. As with any product, there is better quality along with barely get by meeting the specs quality. Grease is no different. Premium quality grease will stay put much better than cheaper brands. The oil in the cheap stuff will separate & get past the felt ball seal showing the appearance of a leaking inner axle oil seal. Many front axles have been torn down for seal replacements that were not necessary, the oil was coming from the cheap grease in the CV joint. I do recommend inner axle seals be replaced & seal mating surfaces be inspected while the joint housings are disassembled. I added the info about using poor quality grease because many people have done this rebuild to come out thinking their reseal job had failed because oil still leaked at the ball seal.TOM R wrote:NLGI#2 grease, this is basicly car cv joint grease for front wheel drives right?
Mixing grease & oil is not a good idea, that will most surely leak & possibly the ingredients in your mixture may not be chemically compatible with each other which could cause damage in other ways. Long story short, mixing lubricants in any application is never a good idea unless the spec sheet says it's suitable to do so. Mixing various chemicals can create real problems if done inappropriately.
I thought our joints were tracta joints...Lifer wrote:OK...I did some research, and here's what I came up with. There is no such thing as a "rzappa" joint. There is, however, a "Rzeppa" Joint which is also named after its inventor.
