governor question
governor question
I started rebuilding my carb this past week, and have a question. When I took the governor apart, I noticed that the shaft into the sealed chamber just flops up and down. for some reason I had assumed it was a dashpot, but there doesn't seem to be any resistance to it's movement at all. Is this correct, or do i need to start looking for a replacement governor?
Re: governor question
The shaft should move freely.flobble wrote:I started rebuilding my carb this past week, and have a question. When I took the governor apart, I noticed that the shaft into the sealed chamber just flops up and down. for some reason I had assumed it was a dashpot, but there doesn't seem to be any resistance to it's movement at all. Is this correct, or do i need to start looking for a replacement governor?
Thanks Charles, I was hoping you'd respond, at least now I don't have to try and find a governor.
