Rotisserie for "non M37" work....
refit1701
Post by refit1701 »
Any of you guys have any experience with one of these military rotisseries? They have a 2600lb capacity and were normally used for big engine work. I got one cheap and am going to use it for restoring a jeep..err...non M37 vehicle.
The gearbox is stuck and I need to get that big gear off the main shaft. Any suggestions? I tried a cheap gear puller and I ended up with a broken puller. Maybe get a good heavy duty one?
I am soaking the two gears (worm and regular gear) in penetrant. I can't find any roll pins on the big gear so it should just be pressed on. I'll have to get a pic of the inside of the box.
Any ideas?
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
Master Yota
Re: Rotisserie for "non M37" work....
Post by Master Yota »
A judicious application of heat always works... :mrgreen:
Ray
1953 CDN. M37
1954 CDN. M152
refit1701
Post by refit1701 »
Yeah, we tried that but I think I will have to get some MAPP gas to get it to really work.
-John
S-89 Comm box
