So I could install some limiting straps, but would also like to get a little more shock stroke. The chart below list my (as I see them) options. The top shock (66707) is what I have now.
As my shock with the truck setting on the tires is at 19", and I have 2.5" between the bump stop pads and the frame, I could get down to a 16.5" (or slightly longer as the shock is on an angle), but believe I need a little more short travel to accommodate the axle tilt on a RTI, so I'm thinking a shock that is fully compressed at 16.375".
I like the 3rd from the bottom shock, the 66891. I should gain a good 0.875" of extra downward travel. However the shock is a little smaller in diameter.
