NEW Military GKN 1 piece tubeless M37, M101 & M101A wheels
JIMBOB1111
Post by JIMBOB1111 »
Hi
I have several sets of new tubeless POWER WAGON, M37, M101 & M101A1 wheels for sale.
They were made in 2007 by GKN Land Systems in the USA for the Military.
They are still new in the boxes.
They weigh 35Lbs each in the box.
$150 per wheel
send me a PM if interested
W_A_Watson_II
Re: NEW Military GKN 1 piece tubeless M37, M101 & M101A whee
Post by W_A_Watson_II »
What's the Backspacing, looks greater than the Budd wheels.
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
JIMBOB1111
It looks to be 7.5",
The size is 16x6.5
They are the US Military replacement for the 2 piece wheel. I wondered if the Army was considering rebuilding the old trailers, then didn't?
GKN is high quality, they supply wheels for DEERE, CAT, CLAAS, JCB and others
The NSN # 2530015341110
Here's a pic of the NSN Label on the box.
wheel nsn small.jpg (67.24 KiB) Viewed 11349 times
cuz
Post by cuz »
Jimbob,
Where are you located?
JIMBOB1111
Sorry, I'm in Winder GA 30680, About 1 hour North East of Atlanta
I don't mind shipping them, they're still in their boxes.
Approx box size 19" x 19" x 9" 35Lbs
Here's a cross section view of 1 of the rims
Whoa these are nice...........
W_A_Watson_II
Jim,
I saw the eBay listing, but how many are you setting on?
Will
JIMBOB1111
24 to sell after swapping all my rims out, and I'm sitting on those 1100x16 Michelin XL & ZXL's that got surplussed out of Camp Lejuene several years ago. I'm working on dismounting some of the XLs from the LAV wheels in time for the SS GA rally next month. Thats a job and a half!!!
I can deliver wheels to the SS Georgia Rally, It's less than 1 hour away.
Tanner
Post by Tanner »
JIMBOB1111 wrote:24 to sell after swapping all my rims out, and I'm sitting on those 1100x16 Michelin XL & ZXL's that got surplussed out of Camp Lejuene several years ago. I'm working on dismounting some of the XLs from the LAV wheels in time for the SS GA rally next month. Thats a job and a half!!!
How are you breaking down the LAV wheels to demount the tires? It's simple with the correct tool... :)
'Tanner'
Lifer
Post by Lifer »
'Tanner'
Ain't everything simple when you got the right tool? ;)
JIMBOB1111
I welded a "x" together with a leg pointing down to push on the front of the rim, drilled 4 holes in it to line up with lug holes in the rim. Screw it down to compress the front piece and remove lock ring.
Then take front of rim off, flip it over and pull the rim out of the tire/runflat assembly. Then I lube up the runflat, wrap a chain around it and GENTLY pull it out.
I'd like to see what the correct tool is.
This was the best way I could find on STEEL SOLDIERS & the internet. I have to make a new x with legs,it compressed 7 or 8 tires before it bent. I need to make it sturdy enough to push it down with a bottle jack. It takes too long to screw the 4 huge, fine thread fasteners down. The tire almost fits in my 50 ton press, they're about 3" too big, if they fit in there it would be a much easier job.
I have found pulling the rim out of the tire/runflat the hardest part.
I put some old 265/75-R16 D Truxes Radials on one of my M101A1 trailers yesterday . It looks pretty good lowered the bed height some.
trailer tire small 2.jpg (88.34 KiB) Viewed 11241 times
JIMBOB1111
sold out
powerwagontim
Post by powerwagontim »
When I have taken LAV rims apart, I use a tooth on my backhoe bucket to press it down. Only way I have figured to get the runflats out is to reach in with a sawsall and cut it in half, and corkscrew it out of the tire. There is just enough room in between the tire casing and the runflat to carefully use the sawsall without cutting the casing.
A pain in the butt no matter how you do it!
Tim
rickv100
Post by rickv100 »
Has anyone contacted GKN to see if these are a stock item?
Rick
ChadNC
Post by ChadNC »
powerwagontim wrote:When I have taken LAV rims apart, I use a tooth on my backhoe bucket to press it down. Only way I have figured to get the runflats out is to reach in with a sawsall and cut it in half, and corkscrew it out of the tire. There is just enough room in between the tire casing and the runflat to carefully use the sawsall without cutting the casing.
Tim
The tire store I took mine too used a very similar method - they use their big truck tire machine to grip and spread the bead so that they can use a sawzall to cut the runflat out. I was worried about them cutting/gouging the tire but they felt it was safer than pulling the runflat out with a hoist etc. Cost wasn't too bad either (I did have to loan them my sawzall since they burned theirs out working on the front tires of a backhoe the day earlier) and it helps that they are familiar with runflats in logging and construction equipment.
Chad
