Fuel tank gasket
Fuel tank gasket
I have to replace the gasket on top of the tank where the sending unit is is there anything I should put on the gasket like a sealer or something? Any other things to check while I am replacing it?
Re: Fuel tank gasket
The best thing you can do is go to your local NAPA & get a new rubber gasket, listed in the Balkamp Catalog in the gauge section. The cork isn't much at best.dman wrote:I have to replace the gasket on top of the tank where the sending unit is is there anything I should put on the gasket like a sealer or something? Any other things to check while I am replacing it?
