Cab Top Help
Cab Top Help
I put the soft top on my M37 last night and can't seem to get the front/windshield edge to stay put.
The canvas top has the rope bead in it but I think the rim at the top of the windshield is too wide. Is there another part missing or do I have to crimp down that lip slightly?
Snug
It should be very, very snug? I'd be real careful closing the gap in the windscreen!
greencom
Post by greencom »
The channel in my windshield frame was opened a bit too much and the bead kept popping out at the ends. I used a block of wood and a hammer to close it up a bit until it was snug.
Greencom
Mine was mashed nearly flat. After opening it back up I bought a 6 foot long, 3/8 steel rod, inserted it all the way from side to side, then re-sized the channel-perfect fit!
I used a "C" clamp and a block of wood last night to close up the gap. I will reinstall the top tonite.
