windshield hold down brackets?
we took off dads hard top and there are 2 pieces cut off the top of the windshield frame guess for the hold downs? and i think the cab soft top straps run through em? anyone got pics of these/ measurements so I can make em and weld em back on, thanks
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
ok bruce I need to go through dads stuff to see if we have the two bolt on tabs, but the weld on ones next to those that the window hold downs are hooked to are the ones i need pics of so I can make em and weld em back on (probly clear as mudd lol)
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
Windshield Pic's
does anyone have a pair of the bolt on tabs pictured for sale ?
and what goes in these tabs?
bruce how tall is the welded on tab is and how long after the bend also thanks
also we have J bolts and U bolts with the soft top frame where do they go?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
Nuther Pic
J & U bolts anchor either pilar from the inside, on the lower end of the rear pilar.
Which one is the bottom one, I think it's the "U".....but I've been wrong before?
I did a dry fit a while back, it worked for me then.
Welded tab, 1.5" tall, 1/2" turned down. Either one looks easy to fab, but if Jon Bizal has 'em.......
Re: Nuther Pic
You're right. The "U" goes on the bottom, and the "J" goes on the top. The reason for this is that there's not enough room to get a wrench on a second nut at the top due to the "fold-over" of the sheet metal.m-37Bruce wrote:J & U bolts anchor either pilar from the inside, on the lower end of the rear pilar.
Re: Nuther Pic
i still don't see where they goLifer wrote:You're right. The "U" goes on the bottom, and the "J" goes on the top. The reason for this is that there's not enough room to get a wrench on a second nut at the top due to the "fold-over" of the sheet metal.m-37Bruce wrote:J & U bolts anchor either pilar from the inside, on the lower end of the rear pilar.
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
Look for the two round holes in the topp of the cab corners, then feel underneath them and you'll find two slots below each one. When installing the bolts, you loosen the nuts as far as they'll go, slip the "U" of the lower bolt through the slot and the "J" of the top one through the upper slot with the nut towards the center of the cab. Then, slide the tubes of the top frame down through the holes and the bolts (may take some jiggliing and require extra hands). Once everything is in place, you can tighten up the nuts. The concept is simple...actually doing it can be frustrating and you'll probably scuff up your knuckles a bit.
Did It Once
I'll see if I have a pick of the slots?
ok now i see what you are talking about, they are slots that face rearward, we will need to remove the soft top frame to instal the u and j bolts
what are the straps that goto the footman loops on the dash and the bolt on brackets on the windshield frame? are they supposed to be permenantly attached to the soft top? or are they just like a long 1" wide strap?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
