front knuckle felt
vinkon3775
- PVT
front knuckle felt
hi guys;can anyone tell me if the front knuckle felt is supposed to be installed dry or not . i've never changed one and i can't find any info on the subject. i'm getting ready to install one of ray's front disc kits and figure i should freshen up everything in the front end while i'm at it.
Firefighters still make house calls.
- HingsingM37
I soaked mine in light oil. Squeezed out the excess and installed them. I do not recall whether I was told to do this or read it but it seemed SOP for felts in the past on other vintage machines I had worked on.
vinkon3775
- PVT
front knuckle felt
thank's david. i didn't think they should be dry, but i just did't know for sure. when you say light oil;do you mean something like a three in one oil?
Soaking in oil isn't needed. When you fill the knuckle cavities with new grease, the oil that is in the grease will soak into the felt extremely fast. All the oil you put on them from soaking will only wind up on the floor.
- HingsingM37
I used Marvel Mystery oil. It was a messy operation. I did not know these could be installed dry. I would do as Charles recommends as I had oil dripping for a few days as the felts wrung themselves out
vinkon3775
- PVT
