Distributor 180 out
hndrsonj
Distributor 180 out
Post by hndrsonj »
So I have a rebuilt and a NOS military distributor. I had the rebuilt one in but it isn't advancing, so I removed it and put in the NOS one. It is now 180 out. I figured the easiest thing was to just change the position if #1 by rerouting plug wires but the #6 is about 1" too short to do that. I really don't want to mess with the oil pump; how hard is it to change the distributor shaft so it's 180 out so it goes back in without pulling the pump?
Re: Distributor 180 out
You shouldn't be able to. It's supposed to be indexed.
The rebuild probably isn't advancing because it is assembled incorrectly.
hndrsonj
Post by hndrsonj »
I talked with Matt at VPW. Going to switch the cam on the NOS distributor to 180 out and it should drop in.
