M37 Horn Button
Posted: Wed Jun 21, 2023 12:21 pm
What am I doing wrong with my horn button? The old horn pieces were broken. I got a new kit for the horn button.
I put the steering wheel over the steering shaft, then the metal horn finger thing, then the nut and tightened it all up.
When I put the wire in place I have the split plastic holder down in the shaft, then metal washer and then rubber washer.
When I go to put the large spring and the three-finger horn metal piece on to check the clearance I can’t get it on because the rubber washer is sticking up too high.
Can anyone see what I am doing wrong that causes the button assembly to not go down far enough for the three fingers to get below the metal holder piece? I got it together once but the center contact on the top button piece was constantly touching the center metal of the wire end and there was no spring action.
