Can somebody tell me what size the hood star is? Approximately, of course.
Stencils I've seen available online come in different sizes (22in, 20in, 16in.....). Even people in Steel Soldiers claiming their truck "arrived" with a 24" star!
I know the right place and position:
*Hood: pointing forward / must be seeing even if the windshield is down.
*Door: as close to the center of the panel al possible.
I don't mind the size for door, to be honest. Although if you want to share, no problem.
Hood and door star size
Sebastian
- milstencil
- CPL
Re: Hood and door star size
20" hood
16" doors
6" front bumper & tailgate
10" in front of door mounted spare tire
16" doors
Thank you for your contribution.
And let me tell you that I've checked before and forgot to mention that the link in your signature doesn't work. At least for me.
Sebastian
I believe the guidance is that the National Symbol (5-pointed star of lusterless white, Color Chip No. 37875) will normally be applied to all tactical and combat vehicles and appropriate equipment in CONUS and overseas when issued to U.S. Army units to the front, rear, both sides, and top of the vehicle. It will be located on the largest regular area and as near as possible to the center of such area. It will not be applied in a location where it will be obscured in normal usage by paulins, canvas doors, folded-down windshields, gasoline cans, communications equipment, or other such items.
The National Symbol will be the largest size practical for use in the available space but will not exceed 36 inches measured between opposite points. The star will not be applied in sizes less than 6 inches between opposite points (this may be why some people say they got their trucks from the Army with a larger 24" star).
The recommended size for most trucks is as stated above - 20" Top of hood, 16" Right & left doors, and 6" Tailgate & front bumper and would be measured between opposite points on the star. Recommended size for ¼ Ton Utility Trucks (Jeep) is 20” Top of hood, 6” Right & left sides, and 6” Front fenders or cowl.
On horizontal surfaces the star will be applied with one point directly toward the front of the vehicle or equipment; on vertical surfaces the star will have one point directly up.
