Data plate
Posted: Thu Dec 15, 2022 2:10 pm
by 808morgan
I found this data plate in my glovebox and I was told my truck is a 1952 M-42, it does seem to have the holes etc.. and more antenna mount locations etc.. for the radio in back. But I have been looking at how to register the truck on here and the numbers don't make sense with the lists. I have not looked into this at all and if anyone can explain that I would be grateful.
- Data Plate M37 shrunk.jpg (166.11 KiB) Viewed 2697 times
Re: Data plate
Posted: Fri Dec 16, 2022 5:47 pm
by Murf
Register it with the frame # located on the left outside frame rail by the steering box.
The command kit was just an add on after production.
Re: Data plate
Posted: Sat Dec 17, 2022 9:28 am
by PoW
Early trucks usually start with 800- or 8025- serials. 8 digits.
The little tag on the engine side firewall is just a factory number, means nothing.
Re: Data plate
Posted: Wed Dec 21, 2022 9:59 am
by 808morgan
Oh ok, I thought the numbers would match, thanks!
Re: Data plate
Posted: Thu Dec 22, 2022 4:47 am
by sturmtyger380
Oh, now you are in trouble! Those plates are supposed to returned once the truck is no longer used as an M-42.
Re: Data plate
Posted: Thu Dec 22, 2022 7:00 am
by ez8
Kind of like those tags on a mattress, right?
Re: Data plate
Posted: Thu Dec 22, 2022 10:00 am
by 808morgan
Yeah that's true! I was surprised to find it in there. Now I'm trying to find tubes for my 1100R16 Michelin tires and it's not going well. I may really be in trouble.
