M37 with 318 poly..
junkyardog
M37 with 318 poly..
Post by junkyardog »
Got a good deal on a m37 with a 318 in it and a parts truck.. its had alot of work done to the engine but it sat a while.. it turns by hand so that was why i went ahead and bought them.. the other one has a new set of tires but is basicly a parts truck.. if there are any decent cabs around i would be interested..
Re: M37 with 318 poly..
Just to be clear, a cab is what you sit in. A top goes on it.
That is, unless you're fighting rust, then you need a cab.
junkyardog
yes i need a cab you sit in.. i have a top.. there is a bit of rust on the cowl area and floors as well were the floor plates bolt.. there not that bad to change.. it runs well so its worth putting a cab on.. got to find one first..
greeno
Post by greeno »
Jon has a lot of stuff in his yard, but always been snow covered when I was there. Worth a call. Midwest Military
M37
YEAR: 1954
You can check out Chrysler Power for 318 poly stuff, pretty cool stuff.
ericke33
Post by ericke33 »
Are you by chance selling any parts of the surplus truck you have?
junkyardog
ericke33 wrote:Are you by chance selling any parts of the surplus truck you have?
not much on it savable as far as sheet maple goes.. tail gate is very straight but rust on the bottom round piece.. taking the good tires off and going to try to save engine and trans for my civilian truck.... what do you need
