Fired it up !
Posted: Sat Dec 12, 2020 1:40 pm
So for the 1st time in... I don't know how many years, I got back to the truck that had become the resting spot for so much crap and other projects in the garage. After digging it out and spending lots of time on different stuff with it, I put the rebuilt carb on. I have always kept the engine "free" by hand turning it every-so-often. After pulling plugs and dropping in a bit of penetrant and oil to circulate I turned it over under and got good compression. Today I plumbed it with a gravity fed fuel bottle for a gas tank and let her rip. She fired up after some coughing and fiddling with the choke. After the mosquito screen cleared she cleared up. Oil press, volts, temp all were responding. After the 3rd bottle of gas she's purring pretty darn well. No knocks although I need to address a couple of disconnected vacuum lines. I will run a few more heat cycles to sort things out and fine tune the timing and carb.
No one blew up so I'm calling this a WIN!
